Copper Alloy Brake Lines
seabeelt
Patron 2019
Patron 2019
Post by seabeelt »
Anyone ever use the copper ally brake lines? Vicks has then for a few bucks cheaper than the regular steel package, both are sold out. I know you can buy lengths of the tubing. Does anyone remember the size (mm)? and what type of fittings are on the end (flared ???) I seem to remember reading a post somewher that there was some sort of a special tool required to make the ends and that it was somewhat expensive........
Many Thanks.....
Since I started the post I have found a couple of youtube videos that might be helpful.
The first is the making of a bubble flare (which is what I think we have) using inexpensive tools...
http://www.youtube.com/watch?v=HVbHk0kkX8k
The second is a video explaining the different types of fittings/flares and their uses
http://www.youtube.com/watch?v=BcUGBdY1 ... re=related
And then last is a standard double flare.
http://www.youtube.com/watch?v=4fmF9mm3 ... re=related
Further research on the Forum gives us the 10mm x 1.25 fittings.
The only remaining piece of information is the actual size of the line or can we use an SAE size line with the metric fitting :roll:
OK last piece of the information is that the tubing is 3/16" or 4.75 mm
All of the stuff we need is available here: http://store.fedhillusa.com/britishgirl ... tings.aspx
They have the 10 mm x 1.25 fittings as well.
Divers
Re: Copper Alloy Brake Lines
Post by Divers »
Did my whole car with this stuff. Easy to work with.
Robert
baltobernie
Post by baltobernie »
5/16" for supply and vent, 1/4" for return, 3/16" for brakes. One 25' coil will do all the brakes.
The 3/16" stuff really bends easily, the 5/16, not so much.
I do not recommend Fed Hill for the fittings. The "business end" is the correct metric pitch, but the nut is SAE.
seabeelt
Patron 2019
Patron 2019
Post by seabeelt »
Where did you get the correct fittings or did you live with the SAE nut size?
baltobernie
I used the ones from Fed Hill, since returning them would have been bothersome. I just borrowed a sweet Snap On wrench from a buddy. These may have been a fluke. You could contact Fed Hill with your concerns, or just get them somewhere else; they're not that rare.
tartan18
Post by tartan18 »
When I replaced my hard brake lines I got SAE to metric brass adapter fittings from NAPA. The counterman told me that his book showed the adapters as being specifically for Fiats. As I recall the adapters were about $8.00 each.
Jim MacKenzie
1975 Fiat Spider
