Gas Tank Pressure
Tuggertim
Gas Tank Pressure
Post by Tuggertim »
Hello All,
I noticed that my gas tank has a massive amount of pressure when I remove the gas cap. Also, the car is running extremely rich, but cranks and drives fine. I saw that there is a two way valve in the vapor vent line to the tank, could this be the culprit? Or, is this normal to the car? Does anyone have a part number for a fuel filter? My local parts stores are have a bit of trouble looking up my car. 1984 Pininfarnia Spider Any help is much appreciated!
Tim
Pensacola, FL
Re: Gas Tank Pressure
Is it pressure as in positive pressure OUT? Or vacuum pulling IN?
Tuggertim
Post by Tuggertim »
Positive pressure out, it actually blows the cap off at the last thread then continues to vent.
Very odd. I have no clue on this.
BEEK
Your car is a: 1975 Spider
Post by BEEK »
you have a blockage in the gastank /evaporative system
75 spider
son has 78 spider
Shouldn't that create a vacuum?
djape1977
Post by djape1977 »
whatever is the cause, vacuum or pressure, breather hose is blocked
Just curious, how does that pressurize the gas tank?
rlux4
Post by rlux4 »
Gasoline evaporates, and without venting the gas (vapor) builds up. You've probably seen this with gas containers, especially in the summer. Without a vent cap left open they can puff up pretty good.
Ron
Ron Luxmore
rlux2n2@gmail.com
Tuggertim
Post by Tuggertim »
Many Thanks, I will check it out this weekend.
Tim
majicwrench
Post by majicwrench »
I have seen a lot of cars with pressure in the tank. Not saying everyting is OK, just lettin you know that a certain amount is normal.
Keith
So evaporation due to temperature rise would raise the vapor pressure in the tank. That makes sense. Then the Evap Control system should relieve that, through the charcoal canister, therefore it seems likely that there is a blockage in that system, as was originally suggested.
