my engine size
fiat218
my engine size
Post by fiat218 »
i looked for the numbers today on my 72, i can't find the numbers that would identify the engine size. i looked above the oil filter , where else should i look?
thanks
Re: my engine size
there are two spots on the left side of the block that could have numbers
kmead
Re: my engine size
Post by kmead »
Go to the source:
http://www.artigue.com/fiat/tuning-book
124 Model Series From S/N Engine Displacement
Spider 1968 124AS 0005619 124AC.040 1438cc
Spider 1969 124AS 0010554 124AC.040 1438cc
Spider 1970 124BS 0021861 124AC.040 1438cc
Spider 1971 124BS 0022589 124AC.040 1438cc
Spider 1971 124BS1 0033950 125BC.04 1608cc
Spider 1972 124BS1 0047032 125BC.040 1608cc
Spider 1973 124CS 0059592 125BC.040 1608cc
Spider 1973 124CS 0063308 132AC.040.3 1592cc
Spider 1974 124CS1 0071650 132AC.040.3 1756cc
Spider 1975 124CS1 0088792 132A1.040.4 1756cc
Spider 1975 124CS1 132A1.040.5 1756cc
Spider 1976 124CS1 0099909 132A1.031.5 1756cc
Spider 1976 124CS1 132A1.031.5 1756cc
Spider 1977 124CS1 0113343 132A1.031.5 1756cc
Spider 1977 124CS1 132A1.031.5 1756cc
Spider 1978 124CS1 0126001 132A1.040.5 1756cc
Spider 1978 124CS1 132A1.031.5 1756cc
Spider 1979 124CS2 0142649 132C2.040 1995cc
Spider 1979 124CS2 132C2.031 1995cc
Spider 1980 124CS2 0157654 132C3.040 1995cc
When too much info is never enough:
http://www.netikka.net/ville.vieri/tc/tclist.htm
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
fiat218
Re: my engine size
Post by fiat218 »
me and my mechanic looked on the block and could not see it . but it has to be there
kmead
Re: my engine size
Post by kmead »
Perhaps a bit of emery cloth run over those flat spots on the block will bring them up so you can see them. The links I posted show the places to look depending on what block you actually have.
I would expect you have a 1608 though given the easy interchangability any year engine could be in there...
Karl
1985 Bertone X1/9
fiat218
Re: my engine size
Post by fiat218 »
well thanks
i actually thought they where all stamped at the oil filter housing. my other engine in my parts car is a 1608 and it is stamp just above the oil filter, so perhaps this is not a 1608 in this 72. i am wondering where the stamp is for a 1800?
there no way there is a 2.0 in this car
so i am ASSUMING that it is either a 1608/1800
djape1977
Re: my engine size
Post by djape1977 »
on the side of the block, under the intake manifold, there's a cast code that looks something like 132c2000, or 125b1000 etc
kmead
Re: my engine size
Post by kmead »
The later engines have it stamped to the right of the oil filter housing. It is on a flat area just below the cyclonic oil separator. Which would suggest it is an 1800
Karl
fiat218 wrote:well thanks
Karl
1985 Bertone X1/9
fiat218
Re: my engine size
Post by fiat218 »
kmead wrote:The later engines have it stamped to the right of the oil filter housing. It is on a flat area just below the cyclonic oil separator. Which would suggest it is an 1800
Karl
THERE WAS NO STAMP at that area/
BEEK
Your car is a: 1975 Spider
Re: my engine size
Post by BEEK »
post a picture of the short breather hose, going from the block to the cyclonic trap, with that pictuer i can narrow it down if not tell you exactly what you have
75 spider
son has 78 spider
wikkid
Re: my engine size
Post by wikkid »
And remember, size isn't everything. :oops: :D
fiat218
Re: my engine size
Post by fiat218 »
BEEK wrote:post a picture of the short breather hose, going from the block to the cyclonic trap, with that pictuer i can narrow it down if not tell you exactly what you have
this help
BEEK
Re: my engine size
Post by BEEK »
back the camera up a little so i can see the whole assembly please, that is the long hose, i need to see the short hose as well where it meets the block and the whole trap
75 spider
son has 78 spider
fiat218
Re: my engine size
Post by fiat218 »
BEEK wrote:back the camera up a little so i can see the whole assembly please, that is the long hose, i need to see the short hose as well where it meets the block and the whole trap
try this one, sorry
do u see the arm on that fuel pump photo, well i orderd a new one for this engine , assuming it was a earlie engine, 1608 or 1800, well any ways this new one ( photo ) the arm is differnt, the one in the car ( i don't have a photo ) has like a u shape end on the arm,
so i am wondering what i have? or if this pump will work
thanks for helping
BEEK
Re: my engine size
Post by BEEK »
from what i can see, it appears that you have a 2.0l i would like to see the whole assembly in one picture. if it is a replacement block the serial # could be on the flat area you see near the breather, not the fuel pump mount. what numbers are on the head. not the casting number but the model # ie 132c2343 etc and no the fuel pump from a 1608 and a 2.0 will not interchange. the arm lengths are different
75 spider
son has 78 spider
