Engine problems
swede
Engine problems
Post by swede »
Gents,
I got into some problems with my new engine.
The flywheel is smaller than the one I had before so the starter motor can’t reach it.
Does anyone have a list that shows what starter drive and flywheel that fits together? :shock: :shock: :(
The new motor came from a 1974 Spider 1800cc (132A1000) if that gives any help.
Re: Engine problems
with the smaller flywheel you need the smaller bellhousing, that will move the starter closer to the flywheel
swede
Re: Engine problems
Post by swede »
So Cal Mark wrote:with the smaller flywheel you need the smaller bellhousing, that will move the starter closer to the flywheel
So changing the bellhouse is the only way?
Man I should have checked this before installing the engine in the Spider, I didn’t realize this until it was time to test run it and the motor starter was running like crazy without turning the motor.
What an idiot I am, now I have to pull it out again and everything has to be completed by Friday so I can attend to the fiat meeting.
Thnks for the info Mark
manoa matt
Re: Engine problems
Post by manoa matt »
What do you need a starter for? Just park on a hill, let it roll, and pop the clutch. Just kidding. Fortunately pulling the trans out is a little easier/faster than pulling the motor and swapping flywheels.
swede
Re: Engine problems
Post by swede »
After the setback yesterday I was pissed and really motivated to get down to business since I have to be done in time for the Saturday Fiat meeting.
The engine was flying out of the car without the slightest trouble and I was quite surprised how easy it came out this time.
3 hours later it was back in the car again with another flywheel and clutch, it will be an easy ride tomorrow to put all wires and stuff back (I hope) :D
The difference sizes between those two flywheels aren’t that big but I learned a lesson, I will pay more attention to details next time. :oops: Thank you Mark for the info of the flywheel.
