Vapor lock
Vapor lock
Took my 1980 Spider out for the first time, since winter up grades. Had some problems, looking for some idea's. Seemed to run good all day, lots of stop and go traffic, never seemed to over heat. Stoped for lunch, came out, started right up, made it about a block, where it died. Pump the trottle a few times, it would start and die. Pulled supply line from carb., cranked it no fuel. Brought it home on a roll back, thanks Hagerty. After 3-4 hours started right up, seems to run fine.
Here's what has been done, it has been desmogged, one of Marks Empi carb's, single plane intake all holes plugged, 4-2-1 exhaust, no cat, stock resonator and muffler, new Mech. fuel pump, no fuel vapor canister, new plugs, wires and coil, cap and rotor. Should I lose the mech. fuel pump and go electric or what. any thoughts?
Re: Vapor lock
when you removed the vapor cannister, did you plug all of the lines? One way to cure vapor lock is to have fuel recirculating to cool the pump. You could use one of those Chrysler filters with the return line
Re: Vapor lock
Mark, do you have more details on the Fuel filter, your talking about. Like year and model of mopar?
- tartan18
Re: Vapor lock
The metal fuel filter I am using that has a return line nipple is made by PTS (Taiwan) with a part number PG3499 which is a direct replacement for the Wix 33054. I found it at the local auto parts store. My car is a 1975 with the 32/36 EMPI DFEV carb.
Jim MacKenzie
1975 Fiat Spider
1975 Fiat Spider
- seabeelt
- Patron 2019
Re: Vapor lock
Have you checked the fuel pick-up strainer in the tank? They sometimes get gooey or plugged with junk and get sucked to the bottom of the fuel pick-up. Can cause very erratic behavior
- 124JOE
Re: Vapor lock
my screen was plugged and very brittle i bought a chevy style and cut it off then zip tied it on the pickup tube
but you need to be carefull as the float is very fragile and mine broke and i replaced it
- opus10583
- Your car is a: 1978 CS1
Re: Vapor lock
Same thing here,right now; a number of mixed drives on the first truly warm day and after a ten minute stop I got about 100yards then dead. Same mods WITH the 3-port filter. Should have 1/4tank by the odo.
News in a beer or two...
Ciao,
Mark
Ciao,
Mark
ANDIAMMO: 2012 500 ABARTH
- opus10583
Re: Vapor lock
Two beers, including the walk to the pub and back, fixed it just fine...opus10583 wrote:Same thing here,right now; a number of mixed drives on the first truly warm day and after a ten minute stop I got about 100yards then dead. Same mods WITH the 3-port filter. Should have 1/4tank by the odo.
Electric fuel pump is now on the sooner-rather-than-later list.
Ciao,
Mark
- opus10583
Re: Vapor lock
Hi Geno,geno58 wrote:Mark, do you have more details on the Fuel filter, your talking about. Like year and model of mopar?
Different Mark here.
This is one I found: http://www.summitracing.com/parts/FRM-G3499
Ciao,
Mark
- 124JOE
Re: Vapor lock
opus from your will kill for that sound comment from a different post
i think you want some of so cal marks cams
he has very diferent styles
and $8 a valve go to his site if you havent
rumble rumble
rumble rumble
