Smoke from tailpipe on downshift and deceleration
RoyBatty
Post by RoyBatty »
Just noticed this today as I approached a stop light.
Downshifted from 4th to 3rd and let the engine do the braking for about 5 seconds then dropped from 3rd to 2nd. Looked in rear view mirror and noticed smoke from my tailpipe. Went away once I stepped back into the throttle.
Valve guides??
azruss
Re: Smoke from tailpipe on downshift and deceleration
Post by azruss »
you got it. valve guides and seals.
124JOE
Post by 124JOE »
you can let it go for awhile
majicwrench
Post by majicwrench »
Rings more likely than valve guides. On decell you build up a whopping vacuum in the cylinders and guess what gets sucked in. Oil past the rings.
Keith
digitech
Post by digitech »
It can also get sucked in past seals/guides.
124JOE
Post by 124JOE »
you can do a leak down test to find witch cylinder/s are bad
