Gas Smell
jfrawley
Your car is a: 1982 Spider
Gas Smell
Post by jfrawley »
Thought I'd pass this along.....I've been fighting this issue for some time now but recently it's gotten much worse. In poking around I found that the smell was strongest around the rubber filler hose to the gas tank. I had replaced this hose a couple of years ago so I was kind of surprised this was happening. Well, it turns out the replacement hose I got from one of our vendors was not resistant to the new fuels that contain ethanol. Found a hose at NAPA (part number 1047) that is ethanol resistant and with just a little trimming, fits the Spider perfectly. Installed it a couple of days ago and now, no more gas smell in the garage in the morning.
John Frawley
Frederick, MD
1982 Spider
http://www.dcfiats.org
baltobernie
Re: Gas Smell
Post by baltobernie »
Did you see any evidence of leaking? I've got the same problem.
Kent124
Re: Gas Smell
Post by Kent124 »
Gates makes good hoses. Amazon has it for $17 and change.
4uall
Re: Gas Smell
Post by 4uall »
1047
Description Gas Filler Neck Hose
Attribute I.D.:2",Reinforcement:Designed Specifically as a Replacement Hose for Passenger Cars, Truck & Recreational Vehicles. Molded Into 45 Degrees or 90 Degrees for Use on Applications Where Standard Hose Will Not Work.
when you mentioned modded or tweaked how so? Any pics?
jimincalif
Your car is a: 1980 FI Spider
Re: Gas Smell
Post by jimincalif »
I replaced mine with a Gates #24717 back in Nov 2009 and have not had any issues with it. Had to trim it to length.
1980 FI Spider
jfrawley
Re: Gas Smell
Post by jfrawley »
Bernie.
No evidence of leaking at all, just a bad smell around the hose. Also it was very soft and "punky" which I attribute to the ethanol getting to it from the inside.
JF
John Frawley
Frederick, MD
1982 Spider
