Nothing registering on gauges at all
Gopher
Post by Gopher »
Fired up the car today just to run it (didn't drive it), but noticed that I wasn't getting ANYTHING from ANY of the gauges...no tach, no oil press, no temp, nada. Guess I am going hunting and cleaning connections.
Re: Nothing registering on gauges at all
check the fuse
Gopher
Post by Gopher »
Fuses are all good. Are there any hidden anywhere?
124JOE
Post by 124JOE »
mine has a ground temanal to the right of the ing up on the rail
are all your grounds connected?
georgeramos
Post by georgeramos »
this recently happened to me when i took the plastic center panel piece out to replace the small wood pieces. As I was driving one of the lights or switches must have grounded and it blew a fuse (i think it was #7) Double check those fuses
sorry to be redundant
narfire
Post by narfire »
A problem I run accross is the contacts in the fuse holders can get corroded to a point current does not get through. I have taken a dremel and a small wire brush type thing and gave each top and bottom a dose of scouring.Fine sandpaper would do the same I suppose.
124JOE
Post by 124JOE »
and bulb grease
4uall
Post by 4uall »
124JOE wrote:and bulb grease
like white lithium grease?
124JOE
Post by 124JOE »
no, dielectric grease
its for electric connections
they also use it on 12v bulbs
it keeps corosion at bay
