i have a 1980 carb 2000
i am wondering how to u do the timing when there no marks, other then lining up the cam etc,\
when the engine is cold it turns over fast and starts, when it hot and u turn it off and try starting it, it acts like it to far advance ( i think ) and or as if it was flood and turns over in a boging way
does this make sense
thanks
timing the engine
timing the engine
Re: timing the engine
So Jim, you don't have timing marks for the crank? The timing indicator is down on the left side of the engine, if you are looking at the engine from the front.
i guess it not on the cover no
i did not look at anything eles
i looked at the right side, i will double check
If it is cranking hard hot, like yoiu have guessed, it is probably too far advanced. If you can't find marks, pull cap, crank engine, watch which way rotor turns, loosen dist mounting and turn dist the same way a small amount. Thjis will retartd timing, If it still cranks hard, repeat. Really, you should find, or make, marks.
Keith
Keith
should have a set of timing marks on an angle piece at about the 10 o'clock position facing the crank pulley.
yes i know it was to advance, i have not checked for the marks yet
thanks
thanks
- 124JOE
pop the hood on your other spider and look for your marks
set your 80 there
the three marks top to bottom
10 btdc
5 btdc
0 tdc
set your 80 there
10 btdc
5 btdc
0 tdc
good idea joe lol. i have 2 others and they should be the same or close
thanks
thanks
my 80 is set on the 5 btdc, i set it there, i was not sure !!!!!! it should be on 10?
- 124JOE
yep
thanks joe
u been a great help,. and the others that have replied
