Burble on Over-run
opus10583
Your car is a: 1978 CS1
Burble on Over-run
Post by opus10583 »
Hi,
I first thought to post this in the Cosmetics section, it's purely an aesthetic issue:
How do I get my newly DFEV-carbed 1800 to burble melodically on over-run?
Mark
ANDIAMMO: 2012 500 ABARTH
boogiedude
Re: Burble on Over-run
Post by boogiedude »
Over run? Do you mean dieseling?
opus10583
Post by opus10583 »
boogiedude wrote:Over run? Do you mean dieseling?
Hi,
No, when you back off the throttle on a downhill run or setting up for a turn...
Mark
GeorgeT
Post by GeorgeT »
That may be a timing adjustment. I can change how my injected Spider sounds when I let off the gas by changing the timing.
124JOE
Post by 124JOE »
remove air cover look down the venturies
give it some gas and see if its followed by a few drops of gas
if you see drops when you let up
then your mixture screw is too far out"play with it untill you have no drops and still has go power"
do you have a vacume gauge
put one on the intake port
dial your mixture screw to get as much vac as you can"i got 15 inch pounds"
Weelan
Post by Weelan »
Joe would that cause or prevent the burble? Seems like that would prevent it, I think the OP wants to cause his engine to make that sounds. I think?
opus10583
Post by opus10583 »
Hi,
So that would be rich on the idle screw and more static advance?
Mark
124JOE
Post by 124JOE »
its rich on the mixture screw
the timing should be locked at 10 degrees BTDC
opus10583
Post by opus10583 »
Hi Joe,
Thanks, but having this car is all about making me grin, and the burble makes me grin.
Turns out less advance might be what I need for that:
http://autospeed.com/cms/title_Getting- ... ticle.html
...Vacuum distributor then?
Mark
manoa matt
Post by manoa matt »
Mark, I don't understand. When you got your 78 with the stock carb you wanted correct jets and spot on jetting, now with a 32/36 you want to have improper timing and improper mix to make a cool sound.
You can get that sound if you drill a small hole in the exhaust pipe near where the cat would be. It will pop and gurgle/burble on over-run. (not serious, but it would)
Regardless the 32/36 should do that anyway because it does not have the fast idle system.
Just messing with ya'
opus10583
Post by opus10583 »
manoa matt wrote:Mark, I don't understand. When you got your 78 with the stock carb you wanted correct jets and spot on jetting, now with a 32/36 you want to have improper timing and improper mix to make a cool sound.
Hi Matt,
...I'm an enigma, wrapped in Krispy Kream.
A lot of what you see is me thinking out loud, a lot is four major projects in the air and needing something to distract me even further while I find solutions, some is whistling past the graveyard.
Mark
TronDD
Your car is a: 1979 Fiat 2000
Post by TronDD »
My Spider does this and I'm trying to get it to stop. :)
Haven't had time to check timing yet (ugh, there is an ugly pun in there), I can let you know what the timing was, if that turns out to be the cause.
Tim.
1979 Fiat 2000
1986 Trabant
1969 Chevelle
2003 Jetta TDI (Daily driver)
124JOE
Post by 124JOE »
124JOE wrote:remove air cover look down the venturies
this may help you then
TronDD
Post by TronDD »
I adjusted the idle mixture last summer with no effect. I didn't have a vac gauge so I adjusted to highest idle.
Tim.
1979 Fiat 2000
1986 Trabant
1969 Chevelle
engineerted
Post by engineerted »
The Burble or popping on Decel is caused by a lean condition in one or even all of the cylinders, the mixtures are too lean to burn in the cylinder and it's pumped in to the exhaust where it is ignited by another cylinders hot gas or even the exhaust valve. This condition is acerbated by adding high flow headers and free flow exhaust systems as this helps lean out the mixtures. So if you want this to stop or reduce the popping Burble you need to richen your idle circuit. On a carbureted car you can only go so far before idle quality start to suffer.
The same goes for adding burble, lean the idle mixture and /or add a flow thru exhaust system or better yet add adjustable cam pulleys and increase the valve overlap.
Ted
