floor padding RESOLVED
txSteve
Re: floor padding
Post by txSteve »
I am considering between EZ Cool and the StockInteriors product (http://www.stockinteriors.com/HeatSound.asp?Itemid=4783) I have seen referenced on here a few times, if anyone has direct comparisons.
I am a little worried about whether the StockInteriors one will hold on to moisture.
Living in Texas, battling the floor heat (as much as possible) is my biggest priority. Plus I think I will get enough "noise reduction" from the Protecto Wrap layer (thanks DocGraphics!) I put down.
124JOE
Re: floor padding
Post by 124JOE »
looks to be the same stuff
both should do great
Re: floor padding
I have a sample in hand of the EZ Cool and it appears to be closed cell foam, which won't absorb moisture. Not sure about the other stuff, but it looks from the picture and description like a fibrous material that may absorb moisture.
4uall
Re: floor padding
Post by 4uall »
When using foam padding or jute backing, unwanted moisture can easily be the cause of early deterioration in the floor of the vehicle.
Less than 1oz per sq. ft.
Excellent fire rating.
No bubbles to pop.
Absorbs NO MOISTURE!
1/4" Closed cell foam.
Reflects temperatures over 900°
99% Aluminum facing.
Reflects 97% infrared heat.
Meets DOT FMVSS 302 standards.
124JOE
Re: floor padding
Post by 124JOE »
ya it looks good
now it looks better :D
txSteve
Re: floor padding
Post by txSteve »
4uall, I noticed you got EZ Cool from another thread. How much did you end up needing? Was one 4x10 roll enough?
4uall
Re: floor padding
Post by 4uall »
txSteve wrote:4uall, I noticed you got EZ Cool from another thread. How much did you end up needing? Was one 4x10 roll enough?
not sure yet as I had a small accident this weekend therefore not yet installed
http://wwwe.fiatspider.com/f08/viewtopi ... =9&t=17531
txSteve
Re: floor padding
Post by txSteve »
Sheesh, don't use the word accident! ;)
Glad you found that BEFORE you did all the work on the floor.
dantye
Your car is a: all gone
Re: floor padding
Post by dantye »
You can use a combo of metal and rubber gas line after you get all the rust taken care of. Just make sure you use Fuel Injection Rated rubber line and really good hose clamps. There is a pretty good photo somewhere on this forum of a restoration that took this approach - you might want to challenge your search skills to find it. I believe IAP and others have complete replacement metal lines as well, but they can be a challenge to install without bending them.
4uall
Re: floor padding
Post by 4uall »
Re: SHE IS ALL BETTER THANKS TO THIS FORUM :-)
Postby 4uall on Mon Mar 19, 2012 2:49 pm
Took the plunge solo and put in new gas lines. Special thanks to all on this forum. Confidence level is higher then when I started. Ran her through multiple cooling fan cycles and no leaks. Also installed nylon filter. Bought face shield makes a huge difference. Next project: this weekend POR15, heat/sound shield, new carpets, new alternator and hopefully lots of driving :mrgreen:
124JOE
Re: floor padding
Post by 124JOE »
:D glad to hear that its going now
i got your check
and your awsome too 8)
4uall
Re: floor padding
Post by 4uall »
stop flirting with me you whore :roll: :oops: looking forward to getting Fiona out so she can stretch her legs and try out all her new parts. :mrgreen:
bluecivicguy
Your car is a: 1975 Spider
Re: floor padding
Post by bluecivicguy »
Hi..thanks for everybody's input and comments...Got to bug..Any advice on using EZcool ?
anyone stuff the center console with it to stop heat ?
I just got my roll..within 12 hours of ordering...(amazing)
Thanks.
4uall
Re: floor padding
Post by 4uall »
here you go http://forum.fiatspider.com/f08/viewtop ... ol#p140435
I have been really happy with this product and will promote it (no affiliation)
supplyguy
Re: floor padding
Post by supplyguy »
Read all 89 posts as I prepare to cover my floor before carpeting. What I cannot find is how many square feet will be needed to do the floor, the hump, and under the back seat area. Very much want to buy Ezcool but their website is a bit 1990's....no pricing, order form, or anything useful to actually make a purchase. Apparently one has to request via email the opportunity to buy their products. I did. I hope they will let me!
