help identify bearing shells
maytag
Post by maytag »
Hey all.
Can y'all please help me identify some bearing shells?
crank-main shell-half says "4361160" on one end, and on the other end, it has a "CL" in a diamond, and then "157" just after it, followed by "5H" below it.
Rod-end shell-half says "4304911" on one end, and "Fm-" on the other end.
I'm thinking I'd order replacements of the same size as what was in there, since they seem to be in good shape. But I can't determine if they are standard size or??
Daniel
Re: help identify bearing shells
Post by Daniel »
Standard size .
engineerted
Post by engineerted »
Yep, Standard size, CL = Clevite FM= Federal Mogul
Ted
maytag
Post by maytag »
engineerted wrote:Yep, Standard size, CL = Clevite FM= Federal Mogul
I wondered if that was the case. But with my luck, the "Fm~" would've been like "Fiat Motors" or "FuManchu" or something. :wink:
thanks Ted & Daniel!
