Fuel starvation IN 5th GEAR ONLY???
MIGHTY 8
Your car is a: 1980 Spider
Post by MIGHTY 8 »
Hello everyone,
In a continuation of maladies affecting my car, I have succeeded in getting to this point.
Car absolutely drives like a bat-outta-hell, and pushes all the way to redline. But, get to the point of shifting up to 5th for highway cruise, and I get all sorts of instantaneous power loss, backfires, (from the engine bay) and related problems.
After a few minutes off to the side of the road.....absolutely recovers and screams up again through the gears.
This is all, after having been picked up from the shop!!
Car is a 2L, equipped with IDFs.
Love to hear your suggestions, please.
Ken
Re: Fuel starvation IN 5th GEAR ONLY???
Post by Ken »
Do you have a mechanical or electric fuel pump? And are you running a fuel pressure regulator?
sptcoupe
Your car is a: 1972 124 Sport Coupe
Post by sptcoupe »
Also, what is your jetting, particularly the needle valve size. Do you have cams, higher CR and a header? And hwat are the float settings?
131
Post by 131 »
Will it sustain 5-5.5K/rpm in 4th instead of changing in to 5th?
Mick.
azruss
Post by azruss »
5th gear is where the fuel pump has to work the hardest. You are not in the sweet spot and your air drag and rolling resistance is high. I would first check the fuel filter to see if it is close to clogged. after that, sounds like a weak fuel pump. If that is the case, the problem will get worse with time.
yep, sounds like fuel starvation. Along with the good advice about the filter, check the quality of the hose from the tank to the pump on the inlet side. There is hose at the tank, near the left rear lower arm and at the pump. Cracks in any of those hoses will not allow the pump to suck very well
baltobernie
Post by baltobernie »
Maybe venting to your fuel tank is marginal. Try loosening your gas cap and see if the problem goes away.
Kent124
Post by Kent124 »
baltobernie wrote:Maybe venting to your fuel tank is marginal. Try loosening your gas cap and see if the problem goes away.
That's a good thought.
MIGHTY 8
Post by MIGHTY 8 »
Thank you everybody for your wise and constructive advice.
Turns out, it was a fuel starvation problem as some of you had correctly surmised. Was told that there was some corrosion/"residue" in the check valve within the fuel system. Not really sure where this valve lies, but can guess that it lives somewhere underneath the car near the elec. fuel pump and the fuel filter.
Drive back from the mechanic's was uneventful, which is more then I can say after having fought this problem since May of '11.
Thank you all and happy safe driving.
ps
And yes....upon a test drive with the mechanic riding shotgun, as the car "died" after reaching cruise speed and in 5th gear, we pulled over to the side, he poped out and un-screwed the gas cap. Car then started right up, and off we went! We had already checked the fuel pump at this point, and could then continue on to pin point where to focus on how to fix the problem.
124JOE
Post by 124JOE »
i told christine to put a huge filter up bt the carb
it fixed her problem
