Exhaust cam wheel
Exhaust cam wheel
Can someone help me out , want to change the cam wheel with the air pump wheel on it on exhaust side to a single wheel from a 1977 spider 1.8 litre. My car is a 1974 spider 1.8 litre.
Nick
Nick
- 124JOE
Re: Exhaust cam wheel
didnt that cam wheel drive the AC?
Hey Joe it did not drive the AC
- DocGraphics
The 1978 1.8l does not have the cam drive smog pump (runs off a v-belt off crank pulley) so a 78 exhaust cam pulley should work for you
Don Raugust
Thanks Don. One more thing to install the wheel , what should I do for the head is on the engine still. Don't want to take head off.
there is no need to remove the head just to replace a cam wheel
Thanks Mark
just make sure you keep that cam still while you are replacing the pulley.
- Turbofiat124
- Your car is a: 1980 Spider 2000 turbo
I would be interested in trading your double pulley for a single pulley if your interested. I'll even pay you shipping to ship it back.nibbes123 wrote:Can someone help me out , want to change the cam wheel with the air pump wheel on it on exhaust side to a single wheel from a 1977 spider 1.8 litre. My car is a 1974 spider 1.8 litre.
Nick
what a deal! If he doesn't want to swap I have a double pulley I'll gladly trade
Hi Turbofiat124 thanks for the offer , but will be keeping the old cam wheel. Mark said he is willing to trade if I did not .
Thanks again
Nick
Thanks again
Nick
- maytag
I'd love to hear how others have held the cam from turning while removing a cam-gear. I've had to be pretty creative.... and I'm not sure I like the solution I'm using.azruss wrote:just make sure you keep that cam still while you are replacing the pulley.
- Turbofiat124
OK. I have plenty of cam pullies. I actually have an intake and exhaust cam pulley from a 1438. Someone told me these were better for some odd reason. Alters the cam timing slightly?So Cal Mark wrote:what a deal! If he doesn't want to swap I have a double pulley I'll gladly trade
I also have a bunch of X 1/9 and Yugo cam pullies. Someone told me these were interchangable with twin cams. I don't know about the timing marks though. I'll have to check.
- Turbofiat124
I once picked up a Spider with the cam pullies reversed. The PO said the engine had 60# of compression yet it still ran, just not very well. Turns out the cam pullies were reversed. The machine shop that did the cylinder head must have forgot the mark them and didn't know which pulley went to which cam and just guessed. He guessed wrong!maytag wrote:I'd love to hear how others have held the cam from turning while removing a cam-gear. I've had to be pretty creative.... and I'm not sure I like the solution I'm using.azruss wrote:just make sure you keep that cam still while you are replacing the pulley.
I wrapped a used timing belt around each pulley (one at a time) then wrapped the slack around the head of a screwdriver handle several times and had my father hold it while I loosened the cam pulley bolt. Then used the same method to tighten the bolts.
Afterwards the compression jumped from 60# to 120#!!
