What Size Air Cleaner?
Kent124
Post by Kent124 »
I have a 79 spider with 2L motor, 1800 single plane, Miller's Mule 1" spacer, and DFEV 32/36.
Will a 2.5" lunch box cleaner fit under the hood? My other option is a 1.75", which I already own.
Is there an advantage of the taller cleaner performance wise? Or in reality is it just a noise thing?
Re: What Size Air Cleaner?
it should fit, but I haven't tried a 1" spacer. Put a piece of foam on top of your air cleaner and see if the hood contacts it
DocGraphics
Post by DocGraphics »
Another way to check clearance is to make a loose ball of aluminum foil & place in the area of concern & shut the hood.
It will compress & not spring back to show you how much space is truly there.
Don Raugust
jsab
Post by jsab »
I have a 79 with the 32/36, 1800 single with 1" spacer and 2.5" air cleaner. It doesn't contact the hood at all.
Kent124
Post by Kent124 »
jsab wrote:I have a 79 with the 32/36, 1800 single with 1" spacer and 2.5" air cleaner. It doesn't contact the hood at all.
Sweet, that is the info I was looking for. :mrgreen:
jsab
Post by jsab »
I don't think that there is any performance difference between the two other than the sound, and I think the 2.5" looks better.
I think more air is more better, larger filter area can't hurt
