Tricks and Tips for Removing Brake Rotor Dust Cap?
parsok
Post by parsok »
Hey Folks,
I'm need to replace the brake rotors. SHort of beating the crap out of the rotor nut dust covers does anyone have a trick they use to get these off and still retain their shape?
Thanks in advance.
Kent124
Re: Tricks and Tips for Removing Brake Rotor Dust Cap?
Post by Kent124 »
Lots of patience :D
Seriously, that and two blade screw drivers of equal size on opposite sides of the cap. Pry (you won't notice anything), rotate hub, <<iterate many times>>. I ended up doing that routine over several days. Was a real pain.
A small hammer to gently tap on the screw driver helps. Try to prevent the cap from getting cockeyed when removing.
baltobernie
Post by baltobernie »
There is of course a specialty tool for the job, but Channel-Lock pliers will often work.
kmead
Post by kmead »
To replace the rotors you don't need to remove the bearing dust cap.
Just remove the spacer bolts and away you go. On the front if it's been a while you may need to do a bit of beating...
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
parsok
Post by parsok »
Thanks gents.
I saw that in the manual about removing the bolts but it doesn't make sense to me ads every other rotor I've ever pulled is held on by a nut. (I guess I have to see it first to understand).
131
Post by 131 »
parsok wrote:Thanks gents.
The cap you are trying to removing covers the nut holding the hub to the stub axle, the disk fits onto the hub and is held in place by the bolts.
Mick.
bobplyler
Post by bobplyler »
parsok wrote:every other rotor I've ever pulled is held on by a nut.
I was talking to a guy at work several months ago. He was trying to replace the rotors on his truck. He wasn't used to rotors that were integral with the hub. He had chipped parts off the rotor with a sledge hammer trying to get it off. Then he looked at the new one. It came of easily after he took off the hub nut. :oops:
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
parsok
Post by parsok »
well i'll be damned, that was the easiest rotor change i've ever experienced. now for the rears and the dreaded emergency brake cable :?
Kent124
Post by Kent124 »
parsok wrote:now for the rears and the dreaded emergency brake cable :?
Those are a piece of cake. Loosed it up per the manual.
