Oil Pan Plug Size?
Re: Oil Pan Plug Size?
the tranny drain plug uses a 12 mm hex driver. the tranny fill plug, and both the plugs on the differential use 17mm wrenches. if you swap to a magnetic oil pan drain plug, you will prolly end up with a 17mm hex head plug....just like the differential.
13mm isn't even 1/64th larger than 1/2 inch. Though I agree that a 1/2" allen key could round off in a 13mm socket under high torque.mbouse wrote:nearly an 1/8th inch off....
Years ago I bought a plug wrench that looks kinda like a mace with various sizes of hex and square drives sticking out of a ball at each end. Don't know if they still make them. This thread was a good heads up. I haven't changed the oil yet (car's in storage) and I wouldn't have the correct wrench with me.
For the casual mechanic, HarborFreight.com has a wide assortment of tools and accessories at inexpensive prices. No, they're not Mac or Snap-On or Craftsman, but I don't make my living under the car. Some recent purchases:
9 pc. metric hex bit socket set, 4 - 17mm, $12.99 (There's your oil pan, cam covers, steering box, etc. for thirteen bucks.)
7 pc. metric crowfoot wrench set, $4.49 Many other "stubby" wrenches, sockets, screwdrivers, etc.
3/8" drive clicker torque wrench, $14.99
40 pc. hose clamp assortment, $4.99 Two sets will do my entire Spider.
Many retail locations, too. They sent me a warranty replacement part for a MIG welder in two days.
That's a good price for those hex wrenches. Thanks for the heads up. I've scoured the local auto parts stores for those silly things.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
on a related note, a set of those inexpensive wrenches are invaluable when you have to bend a wrench for a specialty application such as a carb wrench or dizzy wrench
Like my homemade Chinese dist nut remover?
