sorting out Charlotte mechanic
psg
Post by psg »
Does anyone know of a mechanic in the Charlotte NC region that would be good at sorting out a recently rebuilt 78 spider? I have it starting and idling but no real power so I need someone who can look at it from the carb to the distributor to the cam shims.
bobplyler
Re: sorting out Charlotte mechanic
Post by bobplyler »
Try Gary Baucom at Sports Car Authority (704) 847-7742
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
124JOE
Post by 124JOE »
psg wrote:Does anyone know of a mechanic in the Charlotte NC region that would be good at sorting out a recently rebuilt 78 spider? I have it starting and idling but no real power so I need someone who can look at it from the carb to the distributor to the cam shims.
make a mark at the bottom of the dis to start
lossen the dis and time it by ear "make it faster"then lower your idle at the screw
that wil pep it up
just dont go too far.but play with it
psg
Post by psg »
do you mean the screw at the bottom of the carb or the linkage? and previous post thanks for the name...what can you tell me about his shop?
124JOE
Post by 124JOE »
the linkage
thats the idle screw the one at the base is the mixture screw
mdrburchette
Post by mdrburchette »
The Baucoms are noted for successfully racing Fiats in SCCA for several years and know our cars inside and out. Although I've never taken my car to them, I wouldn't hesitate if needed.
It's possible whoever put the timing belt back on has it misaligned by one tooth or the timing needs bumped up a bit like 124JOE says.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
124JOE
Post by 124JOE »
move it counterclockwise a bit tighten it and go for a short drive
bring a 17mm wrench to adjust it on the road
and youll find a sweet spot
then adjust the idle screw
back down to 900 rpm
majicwrench
Post by majicwrench »
To each their own, but setting timing "by ear" or on the road is not the right way to do it.
Keith
BEEK
Your car is a: 1975 Spider
Post by BEEK »
i have met the Baucoms, they are great people. Gary and his son have great knowledge of fiats. i wouldnt hesitate doing business with them,
75 spider
son has 78 spider
124JOE
Post by 124JOE »
my haynes manual says to time it by ear
ive tryed to do it by the book 10 degrees btdc
and never get power out of it
so i go back to the haynes manual
majicwrench
I would be very interested to see where the Haynes manual says that. I have one, might have to look. Whether it says that or not, doing it by ear is not the right way to do it. If your car does not run well at 10deg BTDC, something is not right.
Keith
124JOE
Post by 124JOE »
chapter 4
section 8
#11
in the haynes
start the car let it warm and drive it 30 to 50mph
listening for pinging ...
BEEK
Post by BEEK »
ok, my .02 worth. i set the timing with the maximum advance at 4000 rpm @ 36 deg, where it comes to at idle i dont realy care, as i am not driving at idle. this is for a performance tune, not emissions tune
75 spider
son has 78 spider
WYSpider
Post by WYSpider »
BEEK, is that timing only for modified engines? Or does it work well for stock engines too?
majicwrench
Wow, the haynes manual does say that! Cept it call it "pinking" in my edition. Why bother with marks and timing lights!
Mickey Mouse.
