Head Gasket Question
I'm changing the head gasket on my 80 spider and I was wonder if you guys use any copper coat on the gasket and any loctite on the threads? I'm pretty new to this and I want to make sure I do this right.
- 124JOE
Re: Head Gasket Question
its best to install head gasket and bolts clean and at tourque .but the last guy used silicone on the bolts
Both surfaces clean, dry,and flat. Nothing on the head gasket. Good idea to chase the head bolt holes with correct size tap.Put a drop of oil into each bolt hole. Tighten to the pattern and torque over two passes. Drive for about 100 kms or so and re-torque.
This was explained to me when assembling my engine years ago and has worked just fine for the several times I've repeated the process.
Chris
Chris
Thanks for the great info. I reused my bolts and snapped the last one off in the block and It was a real nightmare to remove. I'm assuming it was from fatigue because the threads were clean and i was able to hand turn another bolt all the way in. I even torqued it in 4 steps. I ordered all new bolts and a new head gasket from IAP so i should be good to go this weekend. With oil on the head bolts you never had a problem with coolant leaking on top of the head?
- Your car is a: 1975 Spider
if you are using a "print o seal" gasket, a gasket where there are silicone tracings around water passages, dry only. if you are using a graphite head gasket, i would use copper coat. i would also use a very small amount of light machine oil on the threads. dry threads in dry holes mean trouble.
son has 78 spider
son has 78 spider
