2 l engine
fiat218
2 l engine
Post by fiat218 »
is there any way a person can tell if the engine has been modified
seems the 2 l i have in this 72 is like peppy as hell .. and quick
with out removing anything
124JOE
Re: 2 l engine
Post by 124JOE »
are your pistons domed?
or mabey cam has been switched?
and witch carb do you have?
those are some mods to search.
fiat218
Re: 2 l engine
Post by fiat218 »
i really have no clue
i am just comparing the alfa i own, that a new rebuilt stock 2 l engine with fuel enjection and that a dog lol
the 72 fiat has a 2 l and that one peppy engine
i will have see what carb
124JOE
Re: 2 l engine
Post by 124JOE »
pull a spark plug and look at the piston for a dome
you can pull the intake cam cover and write down and cast numbers
fiat218
Re: 2 l engine
Post by fiat218 »
ok kool i will have to do that
i have never owned a 2l so it like wow, this thing UP AND GOES
BEEK
Your car is a: 1975 Spider
Re: 2 l engine
Post by BEEK »
you can make a pretty peppy 2.0 using stock parts. use stock 1800 pistons with a small valve relief, use an 1800 head, now you have raised your compression racio quit a bit. use a 34mm carburator on a 1800 intake. this made 115 hp on a superflo dyno using nothing but stock parts
75 spider
son has 78 spider
vandor
Re: 2 l engine
Post by vandor »
Very true! I did that when I was poor. Wait a minute... I am still poor...
That raises CR from 8.1:1 to about 8.6:1. Better than nothing, but I would not say quite a bit.
Depending on how high the pistons go, one could deck the top of the block for even higher CR.
124JOE
Re: 2 l engine
Post by 124JOE »
and change a cam
engineerted
Re: 2 l engine
Post by engineerted »
2L motor in a 72', that 72 has the 4.30 rear end and that alone will add some git up and go! I have no clue what the alfa has in it.
Ted
fiat218
Re: 2 l engine
Post by fiat218 »
ok thanks , so a 4.30 in a 69 with a duel carb 1608 and mods , will fly
