1980 fiat 2000
fiat218
1980 fiat 2000
Post by fiat218 »
car been sitting 6 years, it fires and runs for a second then stops, fuel pump is pumping, carb is getting gas when i push the throttle,. so possible the float
i just want to see if it runs half azz before doing any real changes
124JOE
Re: 1980 fiat 2000
Post by 124JOE »
if that was a first atempt,thats ok .was the carb leaking?
when they sit they get dryed out gaskets expand slow the next time should go well.
fiat218
Re: 1980 fiat 2000
Post by fiat218 »
look at that picture, that a water pool sitting on top of the intake manifold, i seen it ther so i soaked it up with a rag and when turning it over, it would fire and back fire, so i looked again and the water is back
BLOWN head gasket or what ?
thanks
it on the carb side right up front by the timing belt housing
124JOE
Re: 1980 fiat 2000
Post by 124JOE »
double check all your hoses "coolant"
and the choke has coolant also.
fiat218
Re: 1980 fiat 2000
Post by fiat218 »
ok thanks, the engine is dry other then that spot
fiat218
Re: 1980 fiat 2000
Post by fiat218 »
fuel pump dont work any more now. so it time to swap for a electric any ideas?
124JOE
Re: 1980 fiat 2000
Post by 124JOE »
i pefer a mecanical one
fiat218
Re: 1980 fiat 2000
Post by fiat218 »
thanks . does a 72 2l fuel pump work on a 80 2 l
124JOE
Re: 1980 fiat 2000
Post by 124JOE »
i think so
a carbed motor should take a swap no problemto a carbed motor
fiat218
Re: 1980 fiat 2000
Post by fiat218 »
that what i thought, i have another fuel pump
