Door handle springs
- Your car is a: 1980 Fiat 124 carb
- Contact:
Door handle springs
Anyone got a method for replacing broken door handle springs on a 1980
- danaspider
- Your car is a: 1979 Spider 2000 79 vw bus
Re: Door handle springs
You can find a post I did a while back on the spring. Search for door handle.
I am also pasting the comments below:
The drivers side door handle had started to flop around and it was obvious that the return spring was broken. I removed the lock and hadle and found the return spring had broken one of the arms. I wondered through several of the hardware stores and no one had a spring that was close enough to use. So I wondered through the tool department of the local ace, looking for tools that used similar springs. Surprise there in the discount line was a pair of wire strippers using the perfect spring. I paid my 6 bucks and headed home.
A little work at bending the arms to stay in place and presto! The handle is near perfect.
Just one of those things we learn as we get older, adapt and overcome!!!
Hope this helps a bit.
Luck Dana
79 Spider 2000
carb
It all about the romace of the car and owner
79 Spider 2000
carb
- Contact:
I managed to fix it using a pretty beefy spring from a cheap pair of tin snips and a longer bolt.
https://skydrive.live.com/?cid=d90acd95 ... 67A%212680
Ugly, but hey.. it works..
I took the handle out and drove the pin through and replaced with a used spring from a parts car.
i have a spare set from a 1980 very pitted but all the parts are there $20 shipped in the usa
