OK, I messed up. My dad told me that I needed to bench mark the distributer and set top dead center on #4.
I bench marked the distributer but forgot to turn the engine to top dead center. I think I can remember where the rotor button position was. How can I get the engine to top dead center and rotor on #4 to be sure its right?
Help! don't want to call dad and tell him...
Replacing Distributer
- 124JOE
Re: Replacing Distributer
put the car in 4th push the car forward untill the timming mark on the crank is at the first line nearest the ground drivers side look at the cams to see if your on the right marks youll see cams on there mark crank on its mark.
then pull the dis and replace so the rotor is at #4
Why are y"all setting distributer with #4 cyl. at tdc? thought this should be #1cyl. Dennis
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
- 124JOE
the timing marks from the factory are set for #4
as the book says
and it wont run 180 out
as the book says
I will reset mine when I get home because mine is advanced from #1 tdc. and it does run, just like crap. Dennis
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
- 124JOE
but NOT for the oil aux shaft
So I guess mine is fine? If so I will not jack with it.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
Thanks, I ordered an oil seal and base gasket. should have them any day now. Will put dist back together this weekend and look for the mark you are talking about.124JOE wrote:put the car in 4th push the car forward untill the timming mark on the crank is at the first line nearest the ground drivers side look at the cams to see if your on the right marks youll see cams on there mark crank on its mark.
- 124JOE
this is a bracket they used in factory and is not anywere to be found.
it has pins set to the holes and the mark is at #1 and 4 at the same time.
you can feel for the groove in the crank.the higher flat spot has the mark
but the aux oil gear is most important "it has a hole"to be placed at 1oclock
i set it all up and stand on the drivers side and push the tesion pully with my left hand
while slipping the belt on"halfway on the exh cam and lastly onthe intake"with my right.
you must loosen the tension pully first.
and its not easy to change the belt without pulling of the crank pully but it can be done.as i do it
