vacuum/electrical manifold connections
powellwm
Post by powellwm »
Hello, just bought a 1976 124 spider and was wondering what looks like two vacuum connections behind the carb are and what they hook up to. also would like to know what color wire the carb connection goes to Gray/red?, and the sender unit on the under side of the manifold what wires connect to that? I have a blue and what looks like a pink wire also a brown/black all comming out of the same bundle.... the car was running a few months ago before being taken apart by someone else now I'm not sure about things. also the engine ran about 4000rpm at about 60mph and going between 70-75mph it ran over 5000rpm! is this normal? how can I lower the rpm's at speed? thanks
124JOE
Re: vacuum/electrical manifold connections
Post by 124JOE »
hello and welcome
you need to see this site
http://www.artigue.com/
its all about our cars
powellwm
Post by powellwm »
Hi, thanks for the info, I found same stuff on other sites excetpt for the 1976 which is a little diffrent... i belive unit 18/4 (thermostatic switch for ignition mode relay} in the electrical diagrams is what is under the manifold it has a blue and pink wires going to it. as far as what the two vacuum ports between the carb and head are couldn't find any info about them. I think I'll just plug them off and see what happens.
124JOE
Post by 124JOE »
no theres plenty of info here digrams and pics if you want to go stock
i own a 78.most of the somg stuff is off and vac ports are pluged
ill have to look at some of those wires and colors,
the higher RPMs are normal its the rear end made for city driving.joe
