manifold repair
mik
Your car is a: 1969 124 Spider Convertible
manifold repair
Post by mik »
Started my '69 124AS. Quite a bit of smoke right in the middle where the manifold meets the engine. Seems like I can see very little oil leaking causing the smoke. How difficult is it to take off the manifold and replace the gasket and what type of tools will I need to do the job, or would you suggest I bring it into the shop and have them do it. Trying to do as much as I can myself. Thanks, Mik
WYSpider
Re: manifold repair
Post by WYSpider »
Exhaust or Intake?
124JOE
Re: manifold repair
Post by 124JOE »
oil is NOT leaking from ether one.
oil is in the top end and bottom end.
pick a diferent gasket for an oil leak.joe
Re: manifold repair
on the exhaust side, it's probably one or both of the upper studs that hold the manifold to the head. Those have to be tight and it's best to use a thread sealer too. The cam housing could be leaking also
mik
Re: manifold repair
Post by mik »
It is on the exhaust side. I did notice around the thread of the front bolt some potential oil leak. but there is also a spot where the manifold meets the engine block that seems to be seeping. Thanks for all the feedback
mik
Re: manifold repair
Post by mik »
the leak on the exhaust manifold is in the center, above a bolt, should I just attempt to tighten them or should I assume it is the gasket? thanks mike
124JOE
Re: manifold repair
Post by 124JOE »
just retourque them all for starters if it still leaks afrt a few days go ahead a change it then
