instrument lights
fiat218
instrument lights
Post by fiat218 »
i know there was talk about changing the bulbs in the instrument panels for better lights in the gauges, what where the bulbs. thanks
Danq
Re: instrument lights
Post by Danq »
All of the instrument light bulbs are 194. The indicator lights are 194 as well.
Dan
1981 spider 2000
fiat218
Post by fiat218 »
but are they bright ? mine are dull
Danq
Post by Danq »
How old are the bulbs?
Bulbs dim over time. Also the dimmer rheostat might be affecting the brightness of the bulbs.
Dan
1981 spider 2000
fiat218
Post by fiat218 »
i dont know how old and the dimmer was not even hooked up so who knows
leftfield6
Post by leftfield6 »
I'm going to try some LEDs in place of the stock bulbs. I have what I think are the right ones left over from another project, so the next time I have the dash apart, I'll experiment.
fiat218
Post by fiat218 »
well i thought some fiat peeps was using led lite, and what size would that be? and would u have to order them
124JOE
Post by 124JOE »
i thought the post was on how many watts-3w 7w 12w more watts brighter lights
yes you could find some LEDS to fit but i dont know where.joe
fiat218
Post by fiat218 »
that could be joe. or was it that the led bulbs to hot too
124JOE
Post by 124JOE »
fiat218 wrote:that could be joe. or was it that the led bulbs to hot too
no leds dont heat up
if anything the 12w bulb would be the hottest.joe
Danq
Post by Danq »
I put red leds into my dash this year and I like the result. I go them from http://www.autolumination.com.
I put a blue led in the hi beam indicator, now I can see that sucker. With a bulb in it you barely see it in total darkness.
Dan
1981 spider 2000
fiat218
Post by fiat218 »
what was the number u used ?
Danq
Post by Danq »
My gripe with the web site is that they don't list part numbers on the listing page. Just a lot of choices.
Cut and paste of the led I used for gauge lighting.
"The Widest, 194 168 W5W 2825 Ever Made!
Outfitted with the latest Super Wide High-Flux low profile Leds
Designed especially for gauges, & applications requiring a super-wide large uniform field of bright light
Only 10mm diameter x 26mm overall"
Cut and paste from the cart page.
"T10 Wedge
Item # Super Wide
Color: [color], Lens: 194"
For the high beam indicator
"4- Star SMT
Outfitted with Four of the latest Super High-Flux low profile Leds.
Designed especially for gauges, and constant-on applications requiring extra cooling and regulated current flow
11mm diameter x 19mm overall"
"T10 Wedge
Item # 4-Star
These LEDs are polarity sensitive, so flip them if they don't work.
Dan
1981 spider 2000
fiat218
Post by fiat218 »
thanks dan, i wanted to change mine too
131
Post by 131 »
Interesting that they're $5.99USD, a similar site in Australia has them for $16AUD. The website is not particularly user friendly, do you know if they do international sales?
Mick.
