Well, there's your problem!
sixcharlie
Post by sixcharlie »
I have an '81 with a good drive train and a cancer ridden body. Found a '77 "Won't start" for sale near by, checked it for rust and made an offer. Here's the 1.8 coming out of the car. I think I see the issue.
Looks like the head gasket was leaking for some time and then, one day, this.
So I'm now in the process of swapping a solid 2.0 drive train into the '77 body. Good times.
edit: typo.
bwilson27
Re: Well, there's your problem!
Post by bwilson27 »
Nothing a little JB weld and sawdust won't fix!
sixcharlie
bwilson27 wrote:Nothing a little JB weld and sawdust won't fix!
:D
For the short term, the 2.0 should be just fine. Still haven't decided to go which trans and diff to use.
I'm going to tear down the 1800 and see what other damage was done. I hope the head is in good shape, I have plans for it.
the piston may have given the head a good whack, I'd check it for flatness
Exit98
Post by Exit98 »
Charlie,
IMHO you'll definitely want to use your 81 diff. You won't be happy with the 4.10 gearset in the 77.
You need the 81 driveshaft and other stuff. I made the switch so if you need any info let me know. You have everything you need though.
sixcharlie
Exit98 wrote:Charlie,
Are you running FI in your '77? I know I want to move to the 2.0 drive train the only thing I haven't looked at is pulling power to the fuel pump and the ecu under the dash. I just haven't looked into the wiring diagram yet, too many other little things so far.
Did you swap out panhard rods as well? The vendors list different part numbers with the split in '78/79.
bwilson27
Post by bwilson27 »
That's the same exact spot where my '72 threw a rod back in '82.
Exit98
Post by Exit98 »
Code: Select all
You need the 81 panhard rod. It has a bend on it theat goes with the 81 diff assembly. Brake backing plates are different too. Use the 81's.
My 76 is a stock 1800 motor but the 3.90 gears rather than the 4.10 give the car longer legs. Very happy with the switch.
sixcharlie
bwilson27 wrote:That's the same exact spot where my '72 threw a rod back in '82.
Makes sense. Figure with air flow, the number three cylinder will run hottest. A that spot has a little more air flow restriction with the starter motor right there.
Doug, thanks much. I'll measure the trailing arms to see if they need to switch as well.
Exit98
Post by Exit98 »
Charlie
Trailing arms are the same, all 4. Use the ones on there.
bobplyler
Post by bobplyler »
Exit98 wrote:Trailing arms are the same, all 4.
Not quite. They are interchangeable, but the later trailing arms have different bushings that are supposed to enhance ride. I can't tell any difference.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
sixcharlie
I'm going to try the ones on the '77. Since there is so much rust on the '81, getting the bolts free is a significant challenge. It gets worse if they snap. I just finished prepping the transmission and diff to be ready to install in the '77 tomorrow. I'll spend the rest of the day replacing a couple of the hard brake lines, putting new pads and rubber hoses in, cleaning up and then I'll look at swapping throttle cables (carb to FI) and figuring out how to get power and the correct relay for the ecu and the fuel pump.
Good times. :D
