Vacuum Advance
Vacuum Advance
Should I be using full vacuum or ported vacuum on the stock vacuum advance from my 1980 Carbed 124 Spider?
Re: Vacuum Advance
normally, ported vacuum. Manifold vacuum can be used in certain circumstances, such as compensating for perf cams
- Your car is a: 1979 Fiat spider
Re: Vacuum Advance
On my 79 equipped with a 34 ADF I drilled a small hole in the throttle plate and installed a small nipple to bleed vacume for the distrbuter advance.
