need screw size and type for roof pull handle
minimike
Your car is a: 1979 124 spyder
Post by minimike »
I purchased a handle and the metal ends, but got no screws from the seller. Can anyone remove one of the screws, and
let me know if they are machine screws, with length and size, or if they are sheet metal screws, again with length,and
size please.
thanks.
124JOE
Re: need screw size and type for roof pull handle
Post by 124JOE »
i would go to the store and buy stainless steel bring the meatal ends and get the 1/2" long or alittle shorter
minimike
Post by minimike »
If there's a thread in the hole, I don't want to strip it. Screws are sized like # 6, 8, etc by diameter, and threads per inch.
I'm not up on the metric sizes, but is someone posts them, I can go get what is suggested.
kilrwail
Post by kilrwail »
The screws are Phillips semi-round head, zinc coated, self-tapping, 5 mm diameter (outside of threads), 16 mm shank, coarse thread. A good fastener specialty shop should have them. Good luck!
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
minimike
Post by minimike »
Thanks Peter.
If they're self tapping sheet metal screws, I can put anything in there that will hold. I'm sure I've got something here
around the shop.
mike
minimike
Post by minimike »
I used stainless, # 12 sheetmetal screws x 3/4" long. They did the trick. the head is a bit large, and # 10's might have
worked. Anyone else doing this should try a # 10 first.
baltobernie
Post by baltobernie »
If you ever have to replace a Spider convertible top, it is a great opportunity to fix this weakness by welding in nutplates for these two fasteners. M5 cap screws won't strip out.
