Idler Arm
wikkid
Re: Idler Arm
Post by wikkid »
A dollop of stop-leak in with the ATF will help the health of your seals.Image
tartan18
Re: Idler Arm
Post by tartan18 »
So what is the overall wisdom of you Fiat Wizards ??? AFT in the idler or 90EP oil ... or a mixture. I took off my idler and it was nearly dry ... a lot of metallic "crud." I am going to reassemble with "oil" and if that doesn't work I will buy a new/replacement from one of our vendors.
So ... oil or ATF for now ??
Thanks for your help.
Jim MacKenzie
1975 Fiat Spider
azygoustoyou
Re: Idler Arm
Post by azygoustoyou »
Mix a little oil in the ATF. :mrgreen:
wikkid
Re: Idler Arm
Post by wikkid »
ATF is basically synthetic oil (hydraulic fluid, also similar to fork or shock oil).
minimike
Your car is a: 1979 124 spyder
Re: Idler Arm
Post by minimike »
Can the front of the car be jacked up to effect a proper fill without removing the damper from the firewall?
azygoustoyou
Re: Idler Arm
Maybe if you take the bolts out, you may be able to angle it without jacking the car up. It may take two people to do it. One to hold and the other to fill.
