Weber 32 ADFA 11 rebuild, 78 Spider
psg
Post by psg »
Any particular pitfalls with the rebuild of this Weber Carb? I have leaky shafts and see rebuild kits are available for about 40 dollars. Wondering if I would be better off looking for a rebuilt unit. psg
124JOE
Re: Weber 32 ADFA 11 rebuild, 78 Spider
Post by 124JOE »
if you going to spend some money
try looking for a 34
if moneys tight then a kit
majicwrench
Post by majicwrench »
Leaky shafts?? The throttle shafts?? They shouldn't "leak"
psg
Post by psg »
Tell me more. The shaft ends on the front side of the carb... facing the front of the car are wet and fuel was down on the manifold.
majicwrench
The shafts simply run thru bushings, there should never really be any quantity of fuel there. That said, a tiny amount of fuel will get on shafts and a tiny amount of seepage/sweating from the shaft ends would be normal.
If there is actually fuel dripping from shafts, carb is overflowing or running raw fuel into intake. In which case it needs to be repaired.
Does it idle and run well?? Is there fuel dripping from shafts??
Keith
psg
Post by psg »
It hadn't been running for awhile (body and paint work). Fired it up and ran okay but died on a rough idle. Would not start and that is when I found gas on the floor and the ends of the shafts where wet and there was fuel that ran down the side of the carb pooled on the manifold before hitting the floor. I presumed there were o rings on the shafts that had gone hard.
majicwrench
Nope, no o-rings on shafts. Carb flooding over. As fuel leaks down inside carb some will run out the ends of the shafts.
As carbs go is an easy one to rebuild.
psg
Post by psg »
thanks for the heads up and info.
124JOE
Post by 124JOE »
float stuck open
psg
Post by psg »
yes, that is what I am guessing and since I have been putting off the rebuild as the car has been sitting for many years before I got it this is my excuse to go through it. psg
124JOE
Post by 124JOE »
go right out there and tear into IT shes crying help
6 bolts a few hoses pulls the top
the float should hang 14mm
hold the top vertical or upside down it should lay 6.5 or 7mm
hope this helps. joe
pro4art
Post by pro4art »
psg wrote:Any particular pitfalls with the rebuild of this Weber Carb? I have leaky shafts and see rebuild kits are available for about 40 dollars. Wondering if I would be better off looking for a rebuilt unit. psg
Don't waste money on it. Do some research and get a bigger carb. 34 DMTRA is much better.
psg
Post by psg »
Joe could you clarify the two different sets of numbers you have used?
"the float should hang 14mm
hold the top vertical or upside down it should lay 6.5 or 7mm"
thanks psg
124JOE
Post by 124JOE »
ive bought a few rebuild kits they say 7mm is closed
and 14mm is open/hanging down
is how far the float is to be
i would send a pic but its in my HEAD 8) .joe
