hey guys ive been getting some oil up the tube
making my carb very dirty and smelly
any help?
crank case vent
- 124JOE
crank case vent
- 124ADDHE
Re: crank case vent
Is your oil level high? Some people run this over a bit. How many miles on your motor, maybe its blowbye from worn rings, letting pressure into the motor? I would start by taking apart the whole assembly and cleaning it throughout, then see if you still have the problem..maybe the orignal air-exchange of the breather is no longer sufficient?
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
