Help?
http://www.youtube.com/watch?v=9gNOlCkB ... ata_player
whats making this noise?
- RoyBatty
- RoyBatty
Re: whats making this noise?
They are old.
But they are tight and secure.
The engine does not hop in its mounts at all when I rev it or take off in first gear.
I am wondering if I am hearing induction noise from the carburetor? Something to do with valve overlap?
"Sounds to me"---I really dislike that phrase, but it sounds to me like something is loose and vibrating.
- 124JOE
i had this noise it was a AIR CLEANER NUT that wouldnt tighten all the way i used a washer to stop it
- RoyBatty
Nope thats not it.
I have an after market air cleaner on my empi carb. It uses spring clips.
I have lifted the hood to listen for this noise and it is not preaent.
It makes no change with the clutch in or out. Seems that something in the
drivers foot well must be loose.
- Your car is a: 1982 Spider
These kinds of rattles, bangs, and vibrations annoy the heck out of me and my driving pleasure. I usually get an accomplice (wife, son) to help me find the issue. You need a tube to go from your ear to the suspected area making the noise. You can buy a cheap stethoscope for under $20 at Walgreen's, Wal Mart or other drug store. You may want to rig up an extension to the main tube to reach farther. I have found numerous sources of rattling, grinding, squeaking, etc. just using a long piece of tubing to my ear.
best of luck,
best of luck,
Steve
1982 Red Spider 2000
1919 Old Town Sailing Canoe
I agree with the stethoscope, either a tube type or I have one that is steel wand that you touch to suspected areas. Once you catch the right area, your ears will ring.
- RoyBatty
Thanks all.
I have looked further into this issue and have isolated it to the area above the steering column.
Thats a tuff area to get a hearing aid up into.. Will report more as it is found.
- 124JOE
yes i agree>drivers side footwell
i know this sucks!so this is whati would do.
have a trusted friend or family slitghtly rev her up
while laying (most uncomfortly)up side up under the wheel
touching everything! one at a time,pull wires jently
check nuts and washers,push on frame work
the plastic well,the green powercable
are your gauges tight?im sure youll find it
- Your car is a: 1976 124
air cleaner rubbing on the hood, lift the hood and it goes away, look for the rub spots
sounds like your exhuast system has something loose on it maybe the cat or the heat sheild above it check the
spings as well .
spings as well .
