I have a siezed motor (from Age).
What size is the Nut on the front of the Crank (pulley)
I was going to remove the Rad and use a pry-bar and see if I could free it up..
its a 1600cc.
Crankshaft nut...
Re: Crankshaft nut...
Hi there. Got your message.
Yes a 38mm does the trick but you have put ATF down each plug hole and left overnight at the min and a couple of days was best. I had a 1608 and the atf did the trick after 24 hours or so.
Chris
Chris
