I looked around before posting and while I found a few about accelerator pumps, I didn't see any instructions. I'm leaking from my accelerator pump (at least after looking at diagrams, I'm fairly certain), and having a problem where my rpms drop suddenly during idle when the car is warm. I'm hoping an accelerator pump rebuild kit solves this. I got my parts in yesterday, and I'm not really sure what to do next. Judging by some of the pictures I've found the pump seams to be very similar to a small motorcycle carb. Diaphragm with a spring basically. This weekend I'm going to pull the accelerator pump off and see if I can do this. Is there a good set of instructions to follow, or is it going to be fairly straight forward? 1-pull accelerator pump off. 2- open it up. 3- carb cleaner. 4. replace diaphragm and gasket. 5- put back together 6-bolt back on. This is pretty much how it's playing out in my head. I'm I way off base?
thanks again for all your help. I don't think I could keep it going without this place.
Accelerator pump kit
Re: Accelerator pump kit
I wouldn't think this will fix your idle rpm problem.
The accelerator pump only comes into use when you push your foot down on the gas pedal.
If the accelerator pump is leaking INTO the carb throat and into the motor, it could be an inconsistent leak that is changing your idle RPM. Without a diagram of the Weber carb in front of me, I am not sure that could actually happen, though. You could test this be turning your idle screw all the way closed while it's idling at it's faster speed. If it can idle with the screw all the way in, it's getting fuel from somewhere else.
Tim.
Tim.
1979 Fiat 2000
1986 Trabant
1969 Chevelle
2003 Jetta TDI (Daily driver)
1986 Trabant
1969 Chevelle
Thank you, I heard another problem could be a vacuum leak. The accelerator pump is still getting fixed asap, as I am leaking fuel when I accelerate. Thank you for the advice on my idle issue.TronDD wrote:I wouldn't think this will fix your idle rpm problem.
Tim.
That pump diaphram is super easy, just the 4 screws, make sure when you take it off you don't lose the spring. Pay attention to diaphram and spring and put in same way. Then new diaphram, don't overtighten screws.
Keith
Keith
the pump cover may be warped, causing the leak rather than a failed diaphragm
I hope it's not that, but with my luck I get the feeling it will be. Do you know where online I can get a new one? Searching online is just turning up diaphragm kits.So Cal Mark wrote:the pump cover may be warped, causing the leak rather than a failed diaphragm
Don't assume it is warped, take it off and check it. In my experience is more likely diaphram. IF cover is warped, just put some sandpaper on a level surface and rub cover over it till flat. Diaphram will take up quite a bit of un-evenness (is that a word?) in the cover anyway.
This a simple job, don't make it more than it is. Don't overtighten screws.
Keith
Keith
the problem with sanding the cover is that it takes off the ridge that seals the diaphragm. I'm not guaranteeing it's warped, but I'd look at it closely. It's a common problem on these carbs
As always thanks for the advice, got the new diaphragm in, pulled the throttle and saw no leaks, unfortunately on the first drive to work I broke my idler arm. I love my fiat.
Now remember... F I A T fixing it as thearapyNWAspider wrote:unfortunately on the first drive to work I broke my idler arm. I love my fiat.
