Help - Carb Swap Question
Mirabelli78
Post by Mirabelli78 »
Hi guys,
I am swaping out a 34 for a 32/36 DFEV. My question is what do I do with the 2 lines that went into the water choke on the 34?
anything else I am missing here ?
Rob
Re: Help - Carn Swap Question
connect them together with a splice or cap them
manoa matt
Re: Help - Carb Swap Question
Post by manoa matt »
Just curious why you decided to switch from a 34ADF to a 32/36DFEV. I can only think fuel mileage on the primary circuit.
Mirabelli78
the 34 had a broken main shaft and I acquired the 32 for free.
Mirabelli78
OK I noticed on the new carb that there is no electrical connection for the electric choke.... where does it go?
I noticed a larger gold coloured screw, is this to be removed to add in the choke solenoid ?
I am so bad with carbs...lol
manoa matt
Broken throttle shaft? Would you be interested in selling the 34 ADF? Send me an email to discuss the details matt.scarton@gmail.com
