electronic covertion kit to replace points
74SpyderGates
Post by 74SpyderGates »
Hi,
Does anybody know if by removing the pionts and condenser and replacing it with the electronic convertion kit is worth it. Would the car run smoother and would it effect performance.
tks in advance .
regards gates...
Re: electronic covertion kit to replace points
about the only difference you'll see is you won't have to regap the points twice a year
puddin
Post by puddin »
more reliability and eliminates doubts on the ignition sys. working properly
TulsaSpider
Post by TulsaSpider »
I agree. More reliability, less moving parts
divace73
Post by divace73 »
I say go 1 step further and go for Marks distributerless system click here
Cheers David
see my >>You tube channel<<
majicwrench
Post by majicwrench »
To your question, car will not run smoother nor will it affect performance. On the roads, points are fixable, electronic ignition you are pretty much stuck unless you have replacement part. Points are incredibly reliable anyway.
Keith
