Removing the Crankshaft pulley in situ?
- divace73
Hi all
What is the best way to remove the crankshaft pulley? I was thinking of putting the car in 4th and chock the rear wheels?
It there a better method?
The radiator has been removed.
Cheers David
see my >>You tube channel<<
- courtenay
Re: Removing the Crankshaft pulley in situ?
That's how I did it - except I didn't need to chock the wheels. Just put the e-brake on. You'll need either a breaker bar or impact wrench. If impact wrench, you'll need to remove the lower grill. I had to apply a bit of heat to the crank nut to get it to move.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
- divace73
Hi Courtenay
When you did this was your timing belt on and if so did the belt skip a tooth at all?
Cheers David
- courtenay
Yes, the timing belt was on, and it didn't skip. The reason you have to take the crank pulley off is so that you can get the lower timing belt cover off to provide access to the timing belt. Most people, including me, do not put the lower cover back on once they've replaced the belt so that they don't have to take the pulley off to change the TB in future.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
- divace73
I actually got the timing belt on without taking of the pulley, I seem to have a pulley that had a fair bit of room behind it. I need to remove it as I am upgrading my ignition to EDIS and need to fit the 36-1 toothed wheel. I thought while i had my radiator out to get overhauled, I'd do the lot. You know what's it like with a Fiat, while I've got this off, I might as well do this and so on.
I am trying to get my car complete for this coming Sunday, as we have the Fiat Nationals in Australia, although I am not competing, the 2-3 hr drive to the race track is always a buzz with other fiats making their pilgrimage
Update: Some people on the 124 turbo forum suggest using the sarter motor while having the bar against the ground or chassis. This seems to be a fairly common practice......
Cheers David
- divace73
Further Update
The Starter motor did the trick, got the pulley off have the 36-1 toothed wheel modified to fit. The next challenge was getting it torqued correctly, using a 1.5m bar over the sliding t bar did the trick, it was over the limit of the torque wrench I had up tp 140 ft.lbs.
Cheers David
- 124ADDHE
The starter thing works but could really make a mess of things ( I did when I was younger too!), Now I just put it in gear and wedge the wrench against a piece of wood and the way bar then push the forwards or reverse in 5th (i cunt remember which way). Also, if you place your ratchet on the nut and the handle hangs close to the floor, you can hammer it with a 2X4 (or 2X6, 3pound sledge or a nice taekwondo kick ) a couple of times and this also works.
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
look up my posts and you will find a link to pics of the tool I made on flickr. The thing was on hellishly tight, far too tight infact and I put it back to 124 Coupe factory specs, same motor after all, and had no problems, not from that anyway.
Look up " tool for removing front crankshaft pulley" or something similar Nov, 2006. Gees, was it that long ago ???
I didn't even bother taking the lower cover off when I first changed my timing belt (back in 1980). I drilled/filed/hacksawed the silly thing off (or enough of it so I could get the belt on/off). I couldn't get the pulley off. It's been that way ever since.courtenay wrote:Most people, including me, do not put the lower cover back on once they've replaced the belt so that they don't have to take the pulley off to change the TB in future.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Heat gentlemen heat, and my impact hooked up to 175 psi I'm sure didnt' hurt either, but heat is your friend. (Just in case your still fiddlling with it)
How would one go about removing crankshaft pulley nut on an automatic?
The best way to remove crankshaft bolt/nut is with a big chain wrench. It wraps around the pulley and holds it securely.
Harbor Freight has em. They are generally used for plumbing. Google em.
- divace73
Do some gallery sites work better than others
Just hijacking my previous thread, got the crank pulley of (with the starter motor procedure) and back on with a really long bar, however I digress
I became a member ages ago of the italiancarclub.com gallery and thought I'd try and attach a pic
I know there are some links using flicker etc, my question is
Will some work and others don’t?
Test Pic attach
I keep on getting the X image?
Test Pic attach
Cheers David
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
Hmm, interesting picture.
