3rd gear sync
henry
Your car is a: Pininfarina 1983
3rd gear sync
Post by henry »
I'm having problem with the 3rd. gear again!.... I don't know if is the sync. or not, because the problem starts only after the car runs for a while (hot). Any suggestions, Thank You.
seabeelt
Patron 2019
Patron 2019
Re: 3rd gear sync
Post by seabeelt »
Can you be mor specific as to the problem? Does it not stay in gear?, Is it grinding?
henry
Re: 3rd gear sync
Post by henry »
Grinding.
seabeelt
Patron 2019
Patron 2019
Re: 3rd gear sync
Post by seabeelt »
Anyone else can chime in here, but after just having rebuilt mine, I would suspect the syncnro. When you fixed it last time how did the gear look- any marking or burring? did you change the synchro spring? A silly question, but do you drive with your hand continuously resting on the shifter? It wears on the internal parts. :( How is the fluid level? Is the clutch adjusted properly? Just throwing out ideas here. What ewlse can you tell us??
henry
Re: 3rd gear sync
Post by henry »
Well I didn't fixed the gear myself so I don't know how it looked, I don't know if the synchro spring was changed, I do tend to drive sometimes resting in the shifter; I will check the clutch adjustment and the fluid level. Thank you.
ga.spyder
Re: 3rd gear sync
Post by ga.spyder »
Mine (synchro) has been bad for a couple years now.I missed a shift badly at high rpm :oops: .I still drive the car hard ,but match the rpms to get it into gear w/o a grind.I have gotten pretty good at it.When driving non-aggresively,I skip 3rd gear and go 2nd-4th.I am just saying that it isnt neccesary to pull the tranny right away,you can preserve it for a while.How long...stay tuned!!
Craig Nelson
Fling It Around Turns !
seabeelt
Patron 2019
Patron 2019
Re: 3rd gear sync
Post by seabeelt »
I did that when I lost second gear. Synchro was shot. I would scream in first and then go to third. But since the car is getting a total rebuild from the bottom up, the tranny was on the list. The project has only been going on 7 years and I still dont have it back on the road. Talk about a disease... :oops:
